EE 4G Sim
molly187
Hello,
I currently have a EE 4G sim in my Huawei B535-232 router.
The wifi works very well when i use my phone, ipad and other similar devices however when attempting to connect the router to my TV it doesn’t work.
Ive tried all the usual turning TV off, resetting the router etc however nothing works.
The router connects to the TV however it appears the TV/router are unable to get onto the network.
For reference I have a Sharp Aquos Smart TV.
If anyone has experienced similar or has any advice in order to get the router connected to TV i’d be so grateful as it’s so frustrating
Christopher_G
Hi @molly187
Welcome to the community.
If you hotspot from your phone to the TV, does it work?
Hi Chris,
Sadly it doesn’t which is making me believe the issue maybe lies with the TV itself?
Ive tried an ethernet cable in the past with no joy either.
This afternoon I logged into the routers IP and the TV was snowing as a connected device
James_B
EE Community Manager
Hi @molly187,
I'd recommend reaching out to the manufacturer of your TV for support.
