Fault code YVM102 loss of internet connection
Paul_T5
Hi , I've had EE fibre and TV boxes since April . The main TV box connected via ethernet cable works perfectly well but both the TV mini boxes have regular issues whilst  watching programmes the box loses internet connection and yvm102 fault code is appears.
The only way to reconnect them to the internet is by removing the power cable and resetting the box.  Both mini  boxes are  connected via WiFi to the EE smart hub.
Ive read a few posts about this issue but not found any fixes
Both boxes are on the latest software and WiFi signal is good when working .
Thanks for any help Paul
Northerner
Hi @Paul_T5
That code means loss of internet connection.
Read here:
https://community.ee.co.uk/t5/TV/code-Yvm102/td-p/1429116
