on 10-01-2023 07:56 PM
Hi everyone , I’m trying to change my settings from IPv4 to IPv6 for my Xbox in the Hub settings. On the devices page it list the Xboxone with both IPv4 address and IPv6 address but there’s nowhere to switch between either setting . As anyone come across this and are their any changes I’d be able to do in the settings please .
Solved! Go to Solution.
on 11-01-2023 11:18 AM
You cannot change the IPV Settings for individual Devices from your Hub, you would need to to change any settings within each of the Device Settings itself.
What you can do on the Hub (Router) is change the Routers IPV Settings for All of the Devices that connect to it, this should be do able by setting up and saving a New Profile under the Network or Mobile Settings, you should be able to change the IPV to IPV4/6 or Auto or IPV4 Only, its unlikely going to let you set this value to IPV6 Only.
on 11-01-2023 07:52 AM
Hi @010WILKY010.
Can you see a Network Settings option in the homepage?
One of our mobile broadband experts mat be able to help with this if not.
Jon
on 17-01-2023 11:20 AM
Thanks for the help ,got it all sorted now , the Xbox as both IPV4 & 6 now . Cheers
on 13-01-2024 07:42 AM
Hi can I ask how you did this please ? My sons Xbox will no longer allow chat and I believe this you’re doing might help. His NAT type is strict and I’ve gone through all ports manually and cannot find open
on 14-01-2024 01:56 AM
@Sheilajj : Change the Profile/APN on your EE device to APN Protocol = IPv4 only or IPV4/6.
