on 05-12-2024 12:42 PM
I can use 5g cpe to surf the internet and view all the information in the discord channel, but I can't join the voice channel. Steam also shows no connection.I saw a forum that asked me to set ipv6&ipv4 to ipv4 only. But after I set it up, the 5g cpe could not connect to the network directly.
on 05-12-2024 12:33 PM
I set it to ipv4 only and it disconnected from the internet
on 05-12-2024 12:46 PM
@XRaySpeX Pls help
on 05-12-2024 12:51 PM
I would double check that you have input all of the APN settings correctly, the only thing that should be changing from the Default is the IP Type to IPV4 Only.
on 05-12-2024 12:52 PM
yes i copy all the things and chose ipv4 only,then it will lose internet connection
on 05-12-2024 12:53 PM
Can you provide a screenshot of the details before and after by any chance? Just so we can try and figure out the issue. Do not include any personal details if they are present.
on 05-12-2024 12:57 PM
on 05-12-2024 12:59 PM
i post the screenshot,i'm using ipv4&ipv6 now.if i switch to ipv4 only, i dont have internet
on 05-12-2024 01:02 PM
on 05-12-2024 01:15 PM
