19-09-2023 06:17 PM
Hi
I'm trying to find out more about 5G Home Broadband options but the EE page doesn't seem to work properly? Not sure if this should be in the Mobile Broadband or Broadband forum. Anyway, am I right in thinking that all that is required is a Smart 5G Hub/Router and a 5G SIM card? When I try to check coverage the checker expects me to have a 5G phone, which I don't! At least, not one that is set up for 5G. So I can't be certain of the coverage but selecting a Samsung Galaxy S21 says 5G covers the road of interest. It's also not clear how much it costs for high or unlimited usage. Also what are the pros and cons - specifically the cons!
Is the setup even actually available?
Thanks for any help/advice
Louise
21-09-2023 12:14 PM
Hi @Louise_W_515,
Sorry, we don't hold technical information on the protocols deployed by all VPN providers, or any compatibility requirements. Contacting them directly is the best way to foresee any future issues.
I'd recommend carrying out a speed test over 4G at your new property to get an idea of the available speeds.
21-09-2023 12:45 PM
How can I do a 4G speed test? In the new flat, with my Samsung A53, I get 3 bars at the front window. The signal rapidly drops away as you move back from it. So I presume it would only be any good with 4G if the hub is on the indoor window ledge - nowhere else.
Louise
21-09-2023 01:08 PM
Hi @Louise_W_515,
There are lots of websites available for testing your internet speed. If you search speed test from Google on your phone, you'll be given plenty of options that allow you to test directly from your web browser. There are also app available in the Google Play Store.
Near a window is often the best place to put your mobile broadband router.
21-09-2023 01:13 PM
Ok, thanks
21-09-2023 01:18 PM
21-09-2023 01:40 PM
Oh I haven't decided on it yet. It's a bit of a last result with a 2 year contract commitment. I'm still looking at fibre options.
Louise
21-09-2023 01:47 PM
Please let us know if you think of any more questions @Louise_W_515
