23-10-2024 10:39 AM
I can’t access certain apps and I’ve been told that it’s because the hub uses IPV 6 and not 4 , I have been into the hub control page but cannot see how it would be possible to do it .
Any ideas please ?
24-10-2024 10:29 AM
Thank you very much for your help , I have access to my apps now apart from the alarm system via the app.
Do you have any idea why this is still not working?
24-10-2024 04:29 PM
24-10-2024 05:53 PM
Hi Leanne,
it’s not a camera app but a Pyronix alarm with the Procontrol + app.
no I haven’t deleted and reinstalled it yet as it was working fine with the sky router that I had previously so I didn’t suspect the app to be honest.
But I will indeed try that next .
thank you
25-10-2024 08:35 AM
I am so sorry, totally my mistake it is indeed an alarm app that you mentioned @millsy56
If you could that would be great to see if the changes you have made have worked for the alarm app as well.
Please come back and let me know 🙂
Speak to you soon.
25-10-2024 01:50 PM
I reinstalled the app but still not connecting, in fact the alarm panel is not polling to the cloud despite it having a connection with the 4 G hub and good signal strength?
25-10-2024 03:56 PM
Thanks for trying @millsy56
In this case, please get in touch with our technical support guides and they can get this looked into for you in more detail 🙂
Thanks.
