Fixed IP address for 4G router
bukkko
Is it possible to get a static IP address allocated for my 4G router?
I work from home and services I connect to need to know my IP for security, but it changes quite freqently during the day, even if I don't reset the router.
bukkko
There's nothing peculiar about it. Firewall rules which restrict access by IP address are very common.
Anyway it seems EE can't actually offer me anything other than 4G, which I already have, no it's moot.
I'll have to look elsewhere.
9 REPLIES 9
Northerner
Hi @bukkko
That would not be possible on 4G.
bukkko
That's what I figured.
Is there an alternative? Fibre isn't an option where I live and standard broadband is sub 500Kbps.
EE do not issue static public IPs. The services you connect to can easily see your IP. They have no need to ask you. Many peeps wouldn't know anyway.  This site routinely picks up your IP w/out asking. Just look in your Profile.
Anyway it's safer to have a dynamic IP,
Yes, your services have no need to ask you. It's carried in every browser.
bukkko
The services I connect to only allow specific IP addresses, so if mine changes I need to update it.
This is happening quite often which is a pain.
Most peculiar sites! Most peeps have dynamic IPs. Do these sites preclude them?
Show us some of these sites.
When you resync you'll almost certainly get an IP in the same pool, say the same 1st 2 octets.
bukkko
I've yet to see 1. I subscribe to many sites & never been bounced.
I guess they don't exist then.
My mistake!
