01-09-2026 12:32 PM
Hi EE and all you folk
What is needed for EE to support DYNDNS.. my contract is due to end and before I cancel and go elsewhere what is the situation for DYNDNS to be supported.
Whoever fell out with DYNDNS or EE can you pull your socks up and get this finally activated? It would be good if EE can support the same features as BT hardware.. Currently using the old BT router. Want the wifi 7 setup that i am paying for.
Anyone able to get a email address for getting this on the pipe line?
01-09-2026 12:52 PM
@oldskoolsandhu , there is no email address and I doubt anyone here in the forum can help or get the answer for you.
01-09-2026 05:26 PM
@oldskoolsandhu If it's not on the drop down menu then it is no longer supported as an option.
01-09-2026 06:10 PM
I called them but one think about EE, virgin media, bt and in fact all services.
speaking to anyone about anything more serious then
Turn it off and on again
is just hard work.
thank you tho.. this was a long shot.. going to go back to VF or VM.
01-09-2026 10:08 PM
If anyone knows or can get info on this it is @bobpullen
01-09-2026 10:16 PM
@Mustrum bob already replied about it a year ago on the other post the OP made.
01-09-2026 11:46 PM
@JimM11 so i was right, but the OP did not take his advice and try another option.
But why did you not point that out in your earlier reply, seems odd!
