UpNp and Plex
Huxley777
Hi
Recently moved to EE Fibre and have received the EE Not so Smart Hub Plus
Issues I am having are:
1) UpNp is not detected on any device on my network, it is turned on but not being detected or not detecting anything, I have done the whole turn of everything, restart, turn back on etc and it does not work
2) I use Plex and it is not available outside my network, I have port forwarded 32400 and the external Port that has been configured within Plex I have confirmed with EE I am not on a CGNET and my IP is not within the 10's - I have even placed my server within the DMZ and still does not work. With my old router everything worked flawlessly, in addition my console refuses to come off a Moderate NAT despite all efforts to forward ports
What ever I do this router seems to just ignore any setting I modify, aside from a new router does anyone at all have any solutions to this?
Cheers
7 REPLIES 7
It wouldn't be! Why do you think it might be?
I was merely stating that as people my jump to a conclusion that I am in a CGNET that normally being with in 10 IP range
blc1981
@Huxley777 did you resolve this issue in the end? I've just switched to EE and am having the same issue with Plex.
Peter_W
Good morning @blc1981.
Welcome to the Community!
Just to be sure, have you followed all of the instructions listed here for setting up the port forwarding rules, and are using the settings recommended by Plex?
Peter
chrishumby53
hi i have the wualcom hub with ee and trying to get my plex working outside my network same as you are trying to do upnp switch on and not finding my pc even though I changed pc to static ip for plex and still wont work any ideas please running out of them I use external port 32400 usual one but end internal port im assuming the same just like end external and internal ports no idea what they are any help would be really appreciated I thought 32400 for all of them probs wrong though any ideas would be gt and if you got this even working
thanks for any advice if you have some would be kind of you
cheers
chris
Leanne_T
Hi @chrishumby53
Our Port Forwarding: Access to your home network page has steps to try and set this up, have you tried this?
Thanks.
Just to add, these port-forwarding instructions did not help me gain remote access to my Plex. My previous BT router worked flawlessly - problems only started once I downgraded to the EE router. Any further help or advice appreciated.
