20-01-2026 03:56 PM
I have recently been moved to Digital Home, and have three EE home phones. I want to be able to set the phones so the principal buttons sound when pressed. Trying the Settings option on the limited menu on the phones, and with Keypad tones as On, no sounds are generated. Is the phone defective, or am I missing something?
22-01-2026 10:28 AM
Thanks for coming back with the extra information, @LemurLes.
If you've already got Keypad Tones switched on and you’re still not hearing anything, I'd recommend giving our team a call so they can check the handset details and help look into this further.
Debbie
21-01-2026 12:30 AM
@LemurLes You have done this?
Turn the handset tones on or off
1 In Settings, press Select when
Sounds is highlighted.
2 Scroll down to Handset tones and
press Select.
3 Choose the type of alert tone you
want to switch on or off, then use
the navigation buttons to highlight
the option.
4 When you’ve made the changes you
want to make, press Save.
21-01-2026 09:17 AM
22-01-2026 10:28 AM
Debbie
