Community Activity
Port forward not working with EE smart hub
I just installed the EE smart hub. I'm having lots of problems when I copied port forward rules from the previous router. Most rules were not working. I could not figure out the be pattern. e.g. 9480-9499  udp/tcp worked fine while 5190-5199 udp did ...
BUG souscription
Hello,I bought a prepaid SIM card for work, but I haven’t been able to activate a plan. My mobile data still shows 0/0, and I can’t send any texts—not even to 150 or the other numbers provided by EE. When I try to send a message, it says “Not deliver...
OuDouay by Explorer
  • 22 Views
  • 2 replies
  • 0 Helpful
Tado Internet Bridge won't connect to EE Router
Hi All.I've just changed my internet provider to EE. I was struggling to connect the Tado Internet Bridge to the EE Router i.e. No power, No LED's lite on the bridge.I read other people's suggestions & ordered a TP-Link LS1005G 5 port switch from EE ...
Two signal bars at the top right of the phone
hi I’ve just switched to EE and there’s two reception bars at the top of my phone is one for phone reception and one for 4/5g reception??if anyone knows anything I’d like to know as at the moment I can’t make an out going call
Unable to make calls abroad with full works plan
I have a full works plan but have been unable to make outgoing calls in Australia (included in zone 1 roaming). I have data, have been able to send and receive texts, search online using data but when attempting to call 150 or any other calls, there ...
Luke44 by Investigator
  • 59 Views
  • 5 replies
  • 1 Helpful
