on 07-05-2025 10:13 AM
I have a full works plan but have been unable to make outgoing calls in Australia (included in zone 1 roaming). I have data, have been able to send and receive texts, search online using data but when attempting to call 150 or any other calls, there is no dialling tone before it cuts off as ‘call failed’.
Solved! Go to Solution.
on 07-05-2025 03:14 PM
@Luke44
Please perform a manual Network selection to see if you have Telstra in the list.
If so can you connect to it and make calls?
Ali
on 07-05-2025 09:47 AM
Hi Ali, having the same issue here. I have the full works plan, have arrived in Australia for the first time and cannot seem to make outgoing calls.
Mobile data works fine, I can still receive and send texts, I have 4 bars of 4G/5G, but when I attempting to call any number it does not produce a dialling tone, the a long pause before stating “call failed”. I cannot even ring 150 for tech support.
I have tried manually switching between network providers, resetting my phone (iPhone) but nothing is working.
07-05-2025 10:18 AM - edited 07-05-2025 10:22 AM
Two duplicate threads merged into one.
Have you been able to make calls abroad previously? Whether on this trip or a previous one?
I suspect this is a VoLTE issue with the Aussie networks, but there's 2 bits you don't seem to have ruled out first.
1: Can you manually search for alternative local networks, connect to each in turn and check whether the symptoms are the same.
2: Can you try calling an in-country (Australian) number, and also an international (back to UK) number - is the problem identical? This rules out an international call-bar issue... also why I asked about making calls in my second paragraph.
on 07-05-2025 10:19 AM
Hi @Luke44
While we don't have access to Customer Accounts here at the Community forum, I'd like to get more information about the experience you're facing.
I'll send you private message. Please check your inbox and get back to me when you can.
Ali
@Luke44
Ali
07-05-2025 10:25 PM - edited 07-05-2025 10:27 PM
Yes Telstra has been selected but the same problem is still persisting.
I am unable to call 150, and the same issue occurs when attempting to call local Australian numbers (+61 prefix).
on 08-05-2025 01:39 PM
Thanks for trying @Luke44
Are you able to restart your phone and test?
Ali
on 21-05-2025 08:04 AM
Hi, just following up on this to confirm that after a second attempt the network appeared to work as normal. Thanks for your help
