on 07-05-2025 10:47 PM
Hi All.
I've just changed my internet provider to EE. I was struggling to connect the Tado Internet Bridge to the EE Router i.e. No power, No LED's lite on the bridge.
I read other people's suggestions & ordered a TP-Link LS1005G 5 port switch from EE £11.
It took a couple of days to arrive. I quickly connected it to the router and power supply however, it didn't work....arrggghhh !
I then noticed a USB port on the rear of the EE Router...... would this provide enough power to complete the circuit ?
I disconnected the TP-Link LS1005G 5 port switch and connected the Tado Internet Bridge directly to the EE Router USB port and it worked straight away.
Blimey.... what a faff, heating back online YAY !
Hope this is of some use to you.
07-05-2025 10:53 PM - edited 07-05-2025 11:05 PM
@Russ_EE_2025 : Well, it wasn't gonna power up by Ethernet or WiFi alone. So you had to find the only powered outlet of the router. Either that or plug it in the mains.
08-05-2025 06:37 AM - edited 08-05-2025 06:38 AM
XraySpex - The Tado Internet Bridge was connected to the mains via the adapter..... it wasn't working..... Hence why I suggested using the USB on the router.
