Two signal bars at the top right of the phone
Scott841
hi I’ve just switched to EE and there’s two reception bars at the top of my phone is one for phone reception and one for 4/5g reception??
if anyone knows anything I’d like to know as at the moment I can’t make an out going call
@Scott841  If you have 2 reception bars showing on your device you have 2 sims active in the device.   One will be a eSIM the other a physical sim.
Are you using the eSIM ?  If you open settings>mobile service and scroll down to where is says EE ( left side ) does it show two active sims again one will be a eSIM
Have you restarted the device since you moved over to EE ?
4G/5G *is* your network signal.
That network signal allows voice calls, text messages & mobile data.
