sky glass on EE Broadband
kazz63
Hi will sky glass run on EE broadband
6 REPLIES 6
@kazz63  Yes.  It’s only broadband ie an internet connection.
hi also will it connect to the sky pucks that run the two TV's upstairs thanks
Mustrum
@kazz63   what speed broadband do you have? Is it mobile or fixed line?
Looking on the Sky forum:
"Sky recommend 10Mbps for HD and around 30Mbps for UHD and that's per device."
So if your EE broadband speeds match or better those reccomendations there is no reason why it would not work on EE broadband.
@kazz63  No reason why it can’t.    You need a minimum 10Gbps for the sky glass and a further 5Gbps for each puck that you have.  So you need a minimum 20Gbps broadband.    You’ll read more info HERE
Gigabits, @Chris_B ? I'll have some of that 😉!
Mustrum
That article is out of date. Seems Sky changed the requirement earlier this year to:
