Report a broadband problem without using the telephone
Mark9000
How do I report an intermittent fault on our broadband without calling the Customer Service line?
I am hard of hearing so struggle to use the phone for this sort of thing! Presumably there is another option for those of us like this?
Leanne_T
Thanks for coming back to us @Mark9000
This would need to be reported and we do have the below options for calling us;
To contact us using the Relay UK service, dial 18001 in front of the following number:
07953 966 150
Find out more about the Relay UK service
Contact us through a sign language interpreter
11 REPLIES 11
@Mark9000  You might find THIS  helpful
Sadly not - the only option is a BSL interpreter and I don't do BSL! I simply want a way to contact EE that doesn't involved using the phone. An email address, chat or similar would be ideal.
Leanne_T
Hi @Mark9000
Please see our Fix EE broadband connection problems, Help page for steps to fix this and also how to report a fault to us.
I've tried sending a text to that number but it will not send! The number doesn't seem to work from my mobile (which is not an EE mobile) and I cannot send a text from the landline.
And even if the text did get through, this option also seems to involve a phone call:
  • If you don’t need an engineer, our brilliant UK and Ireland based team will call you within 30 mins to help solve your issue.
Leanne_T
I am sorry this is the only contact options available, you can find full details in our Broadband and landline (ee.co.uk) contact us page @Mark9000
What problems are you having? It may be something the community can help you with?
It's an intermittent line drop issue that involves BT Openreach.
Surely the implications of the Equality Act mean there should be an alternative to a phone call for those who find hearing the phone difficult?
How do you know that the fault involves Openreach other than all EE BB involves Openreach in the normal course of events?
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
Thank you for responding, though your response does sound a little patronising.
We believe it to be a network issue because of previous issues, the fact that all houses on this particular spur are having problems (our next door neighbour and another house are getting each others' calls, for example) and the engineers from Openreach have been to our house to try to sort things out. Unfortunately we cannot go to Openreach direct, hence we have to contact EE to report the current fault and would like to do so without talking on the phone.
Leanne_T
07953 966 150
