broadband speed in linclon
mickski56
Why have I been getting less than the minimum broadband speed in lincoln for months now ?
11 REPLIES 11
Maestro
Maestro
@mickski56What was the advised minimum speed you were quoted, on which device and what package are we talking about? Supply a sample also of your minimum speed...
Minimum Fibre Download Speed is 26.5 Mb/Sec
Maximum Fibre Download Speed is 29.5 Mb/Sec
Minimum Fibre Upload Speed is 4.1 Mb/Sec
Maximum Fibre Upload Speed is 4.6 Mb/Sec
Minimum Guaranteed Download Speed is 23.90 Mb/Sec
Mine is usually around 8Mb/Sec down and 2.7Mb/Sec up
on an .EE Smart Hub
@mickski56 Login to the router manager, http://192.168.1.254 top left click on the status box, take a look at sync speeds up and down, those are what you router is at just now, also the times for network up and system up, capture the screen on yours and attach the picture to your reply. Model of your router is on a label, but attached the link so you can look and compare the name.
What the Lights on Your EE Smart Hub Mean | Broadband Help | EE
mickski56
@mickski56 The picture posted has to be approved and when it becomes available will check.
Quick link i posted of mine sometime ago, take a quick look if you have time.
Re: Guaranteed download speed not high enough to stop service dropping out. - Page 7 - The EE Commun...
What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker.
Don't worry, the images were awaiting approval. I have now done so & they should appear soon.
mickski56
@mickski56 Will let @XRaySpeX carry on with you, he approves the pics and will see your responses quicker, but you sure have a terrible line, and it does look faulty, but the response to the questions will define. Will save you getting bombarded with request's. Good luck, will keep an eye on the post.👌
