22-05-2024 06:57 PM
We've had this hub for a couple months now, 4 or 5 engineer visits and still has not been fixed.
The connection will drop out completely every 10-20 minutes and come back on after 1-3 minutes
The engineers have concluded that the line itself is fine so if the problem persists it may be the hub itself that is faulty (still looking into that).
I've been looking into changing the IPV6 settings because that might be the issue from what I see in the forums but I've no clue what I'm doing, I fiddled about with the ipv6 settings and disabled it which didn't fix the issue, trying to revert it to ipv4 only locked me out of the network altogether so Ive reset it back.
Any feedback is appreciated.
06-06-2024 08:04 PM
@Danielmcg2020 The cable of the foil looks ok nothing to worry about, behind the plate were the cable is there is a connector just like the one on the front for 2 cables to be connected going away to the main line, ? wither new or existing for install. Still really concerned about the sync speed if you are on fibre67. The link below use the address checker will tell you what speed is supplied to your home, if you post hide your address, but would expect it to say 80/20 or there abouts... You will see the wi-fi signal no matter what. and not sure if it is coming from your Tp-Link or EE router. You should always get Wi-Fi, but no broadband.
06-06-2024 08:06 PM
That cable leads to an old phone that I disconnected, we are no longer with virgin at all.
That OR socket was installed when we got the EE Broadband
06-06-2024 08:08 PM
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
06-06-2024 08:14 PM
@Danielmcg2020 OR and VM do not like to play with each other's boxes, but does not stop customers from wiring up as they need, but understand what you are saying, just wondered when i saw the cable connected....
06-06-2024 08:28 PM
"behind the plate were the cable is there is a connector just like the one on the front for 2 cables to be connected going away to the main line, ?" Im not sure what you mean. The semi transparent parts?
Went on that link i'm not sure what an access line ID is.
06-06-2024 08:30 PM
Can't you use your landline no? You don't need Access Line ID when you have a landline.
06-06-2024 08:36 PM
Don't be sticking cables behind the semi transparent covers. They're for extension sockets. The test socket is at the centre top of the backplate.
06-06-2024 08:42 PM
@Danielmcg2020 The ones you are pointing out are not used, the plate screwed to the wall has connection LIKE that were the cable is terminated, as XraySpeX said they are to extend a landline or a dsl connection, but NOT used for any of your connections. Use the address, file in the fields, house number street postcode and it will look up your connection.
06-06-2024 08:45 PM - edited 06-06-2024 08:52 PM
Don't use your address. Use your phone no. It's more accurate. OP has a landline. Use it!
06-06-2024 08:47 PM
According to my partner we don't have a landline number.
