Unable to access EE Hub Manager - Error code CHOP3-800
survesunil
When I try to access EE Hub Manager using address 192.168.1.254, I keep getting error message that something went wrong, with error code CHOP3-800. See the screenshot. Any advice please?
Peter_W
Hi @tmarsh12345, welcome to the EE Community!
If you're unable to fix the issue after selecting OK on the error message, I'd definitely recommend trying a reset on your router using the pinhole button on the back.
When you press and hold this the light on the front should go green, then it'll reboot and switch back to Aqua.
Peter
28 REPLIES 28
Just click the "OK" & it should be OK. Does it often on mine.
Derang
@survesunil @Reboot the hub, I had the same issue and a reboot resolved for me.
Worth a try.
Still tends to do it after a reboot, but it doesn't matter. It's a false positive! Probably due to router's GUI being exceptionally slow.
Yes, my experience is the same. A reboot helps for a while but it happens again randomly. I hope it can be ignored. Never happened with my previous BT smart hub.
monitorcurve
Yep totally normal, the router just sucks and EE don't seem to have any plans to fix the UI issues on the router and the memory leaks.
My SH+'s firmware has been languishing for ages at:
App version: 1.9.0
Firmware version:
App version: 1.13.1
Firmware version:
Recently had to switch to EE's router (had to renew contract from BT) and getting the CHOP3-800 error.  However, clicking ok doesn't fix it, can't access the router at all, sticks at loading logo..
Peter_W
Peter
tmarsh12345
Valued Contributor
Valued Contributor
Thanks.  Will this affect passwords?
