To everyone having Wi-Fi dropouts & other problems - please **report**
Cliff_G
Skilled Contributor
Skilled Contributor
It is now pretty much confirmed that the recent (circa 25/5/26) firmware update on EE Smart Hub Plus (with Wifi 6) to version r4.26.1-R-1860948-PROD-83002 is causing a lot of problems around wi-fi dropouts, probably all on the 2.4 GHz frequency (and probably on both Main and Compatibility). The update was something to do with aligning BT and EE routers, no other details given.
Many people are suddenly getting random dropouts which were not there before, which temporarily stop after a reboot, particularly by powering down for at least 5 minutes.  I personally also found our phones could not even see both Main and Comp networks when the problem was occurring.  Almost universally, the fix is to go into the router Wi-Fi configuration page (Change Settings) and change the 2.4 GHz channel config from Auto to Fixed (many are using channel 6).
I have also seen a laptop reconnect every 6 seconds (to the 2.4 GHz Comp network) where I have tried all the usual - update Wifi adapter driver version, back off certain adapter sensitivity settings - and I even bought a new USB Wifi Dongle, which also would not connect stably. This laptop was absolutely fine before the update (as were the phones that were dropping off the wifi). We're now using that laptop on Ethernet-over-mains, somewhat less convenient but totally solid (and Amazon have refunded the Wifi Dongle 🙂  )
Today I had an excellent conversation with one of the EE Guides (using their callback system which imho is a pretty good way of getting hold of them) and he agreed I'd already done pretty much everything I or EE could do, and will escalate this.
He indicated that any sort of routine firmware update is unlikely very soon, but that they are aware of these wifi problems, and implied (or maybe I read into it) that an update can sometimes be rolled out to fix specific problems.
So I think the best thing to move this forward positively is for everyone to report the problem to EE. Text GUIDE to 66033 and they will call you back in usually less than an hour.  The more who report, the stronger the case.
Before doing this it may speed things up if you do a Factory Reset on your router (under Advanced Settings / System) and then reconfigure it the way you had it before (e.g. turn Comp on, etc.) then check the issue is still there.  We pretty much know this reset does not work, but the support team do have a sequence they need to go through and a Factory Reset is one of those steps, so doing this before will speed things up.
Thanks everyone - fingers crossed.
81 REPLIES 81
Community Hero
Community Hero
@Pervs2 Capture and post your advanced wireless wifi set up screens for both the Main and the Compatible network along with your main status screen so we can see what is setup on your EE Hub. See the linked sample from mine back in the day.
Re: Worst Broadband - Page 4 - The EE Community
Pervs2
Valued Contributor
Valued Contributor
Here they are
Community Hero
Community Hero
@Pervs2 Will take a look at them if they get cleared and approved for general viewing.
Pervs2
Valued Contributor
Valued Contributor
Thank you, do you not see them? I can see them when I scroll through
Community Hero
Community Hero
@Pervs2 You posted them so you see them, NO ONE else does until they are checked and approved for viewing.
Don't worry, the images were awaiting approval. I have now done so & they should appear soon.
Community Hero
Community Hero
@Pervs2 Your Main Wifi and the Comp WiFi settings are now displayed, any device that you find not staying stable and working correctly that is assigned to your main ssid, you should try that device and assign it direct to the comp ssid, they will only operate on the 2.4Ghz band when attached so is ideal for your Ring Doorbell as 95% off those devices are 2.4Ghz band only, think there is only one model operates dual band but have not looked at Ring for a while now, my model is the Video Doorbell (2nd Gen) hardwired for power but just never have issue at all with it, but it is Powerline connected due to the location doors behind it so the signal does not get through to the closest AP in the hallway. See the attached ring snap when cleared for viewing.
Ring Doorbell setting in device health.Ring Doorbell setting in device health.
Part twoPart two
Pervs2
Valued Contributor
Valued Contributor
My ring doorbell disconnected again last night from the network.
I did try connecting it to the Comp network yesterday but it would not connect to that either.
My problem arises as it says password incorrect when it isn’t! I think mine keep disconnecting and struggling to reconnect due to this ‘password is incorrect’.
any ideas on this?
Community Hero
Community Hero
@Pervs2 Connect your mobile out at the same position as your ring doorbell to the Comp Network, see if you get the same password incorrect message, not sure if you have a different password for the SSID on the Comp side if you changed that or not. You will be able to see the password via the web manager interface as it has a show, not sure if the app does that or not.
Pervs2
Valued Contributor
Valued Contributor
So my doorbell is still disconnected!!
I went in and changed the settings to my comp network and I added my network name with comp after it and changed the password to match my other one.
it then wouldn’t let me connect to main network. I restarted the router to refresh it but it still won’t let me connect to either the main or comp network. Saying password incorrect or unable to join network! It’s soooooo frustrating!! I don’t know what to do
