‎27-12-2024 09:00 PM
Hi all.
Im trying to test my broadband speed,i go onto the router page by typing in the 192... number and when i click test my speed it tells me ti create a ee i.d and re directs ne to the app. I already have the app. When i type in speed test in that it says to click Broadband, manage and then the hub tile. Problem is there isnt a hub tile ! Any help appreciated.
‎28-12-2024 12:04 PM
Is yours the Desktop app or is it on a Apple device as mine looks nothing like it. Newest version on Android.
‎28-12-2024 12:24 PM
There isn't a Desktop app. It's an app for Android or iPhone.
‎28-12-2024 03:52 PM
@MikeN73 Android and version 5.52.1 and i think that is the latest updated on Dec 11th.
‎28-12-2024 07:41 PM
Thanks. Yeah that's my latest one. Absolutely 0 way of running the speed test via the app. The assistant in my local EE store said it's recommended to use a independent Speed checker anyway.
‎28-12-2024 07:43 PM
Yep. Absolutely 0 way of checking tue speed on my app. Just kept going in circles (sign in etc) and then nothing works. I was with BT before and had no issues checking the speed on my home hub app.
‎28-12-2024 08:22 PM
@MikeN73 Detailed speed test for you if you wish to try.
Internet Speed Test - Measure Network Performance | Cloudflare
‎28-12-2024 10:05 PM
Thank you. Ive been on the phone to EE who said my wifi was set to a slower speed and they put it onto the faster one (Hz) . Your speed checker confirms that .
