South Northants - Packet loss (15%) - started @20:35
ryanpeterburke
Is there a known issue in the south northants area? Have tested with ping to my router and to a couple of public DNS servers, I drop pings to the public dns servers at the same time as my television starts buffering, no packet loss at all to my router.
Router has been restarted, cables reseated etc.
Thanks,
Ryan
BB faults are rarely area-wide but specific to your particular line.
