Broadband speed
Peter1939
My broadband speeds are now getting really slow.
Ping    Download    Upload
22 ms  3.83 Mb/s  14.44 Mb/s
I am supposed to be getting 35mb/s at slowest, this is ten times worse. Any ideas? EE tech support never answer my emails
