Ethernet Cable Help
Hugo_armani03
Hi I’ve recently noticed a drop off in my network speed so I’ve been trying to look for my Ethernet cable but unsure as to whether I was supplied one or not I’m also unsure as whether EE can supply a new one or whether I can get a replacement elsewhere I only have the fibre 67 box so an Ethernet cable really does help with my network any help will be much appreciated.
Denzel99
Skilled Contributor
Skilled Contributor
When you say a drop-off in your network speed, it might help to be a little more specific about what the problem is.  Ethernet cables tend to work or not, so it may not be the cable.  It is possible, but unusual, for a break in one of the eight wires to drop the speed from 1000Mb/s to 100Mb/s though.
If you want to buy a replacement, you want a cat 5e or cat 6 ethernet cable.  It’s a standard configuration and you can buy them in supermarkets today or on Amazon.  Avoid anything labelled CCA, (Copper Clad Aluminium).  It’s rubbish.  You want pure copper.
Maestro
Maestro
@Hugo_armani03 You noticed a drop off in what, and by how much, is this Internal Network or external to your fttc connection speed?
Ethernet cable can be used, but suspect the DSL port on the back off the EE Hub may not allow the fit for connection as RJ11 would be the preferred 6 pin connection, latter OR Master sockets are fine and support both connections.
shakey19811
Skilled Contributor
Skilled Contributor
at 5e or above for connection to the ont ? if so just buy one
if your own fiber if your still on part fibre FTTC youll need ann adsl cable
Denzel99
Skilled Contributor
Skilled Contributor
@Hugo_armani03   As two people have pointed out, do you really mean ethernet?  To clarify:
For part-fibre/FTTC/VDSL the connection from the router to the phone socket is a telephone cable with RJ11 plugs.
For full fibre/FTTP the connection from the router to the ONT, (the box on the wall with lights on it), is a cat 5e ethernet cable.  They have RJ45 plugs.
The two are not interchangeable.
Lastly, if you are talking about a wired connection from a PC to the router that will also be cat 5e ethernet cable.
