Smart hub pro wan dropouts
Cardiffjamesh
 any one having multiple very short dropouts every device drops out
14 REPLIES 14
Cardiffjamesh
Direct in to router port 1
Cardiffjamesh
Is it even humanly possible to put it before the router lol suppose it takes all sorts to make the world go around
Its a long time since I had one, but I seemed to remember them wanting it between the modem and router, back in the early VDSL days - and can save that   then again my memory is not what it was!!
If you ever get a chance, save the tech log to a CSV fine and attatch it to a post.
I know you said you did not see much, but with a bit of filtereng on Excel it should be possible to see WAN down messages and the frequency.
Cardiffjamesh
Wan logs empty it must be blocked hav u got the smart pro
that does not seem right, no I don;t have one, but if it is anything like all the other BT based routers in the Advance section there is a Tech log, with an Info status page, and an event log tab. They combined are usually the best source of diagnostic info.
