Smart hub pro wan dropouts
Cardiffjamesh
 any one having multiple very short dropouts every device drops out
14 REPLIES 14
Cardiffjamesh
Mustrum
@Cardiffjamesh    do you notice any issues when you are using the service, or is it just your Samknows reports?
Not sure of the exact details, but has Samknows not stooped the service recently?
Cardiffjamesh
Everything drops sky q box’s etc it’s only short sharp and annoying just u can see the amount I can’t tell it I get 1 drop out or 20 lol
@Cardiffjamesh   Ok, so an easy way to look is to log into the router using the admin details on the card and go to the advanced section and the technical log, the I think the second tab and look through the admin log for dropouts.
Or of course just give the Broadband Care Team a call in the morning.
Contact us about your broadband and landline
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
Our lines are currently closed.
Opening hours:
Cardiffjamesh
Iv had a Quick Look at logs nothing jumps out will have a better look tomorrow
help centre where a wet weekend mor concerned about the other mesh node on a hardwired back hall lol saying it’s not meant to be hard wire 😂
Apparently it’s because I’m using a switch lol the wan is dropping out
@Cardiffjamesh    just a thought, where is your Samknows plugged in?
Hopefully not between the ONT and Router!
