EE Smart 4G Hub
jockwav1
Hi,hopefully someone might have the answer to this.
I bought this hub from EE shop about Jan 25,it works ok but i have to re-boot it every single day without fail.
It is driving me nuts,hope someone can help.
38 REPLIES 38
Leanne_T
Hi there @jockwav1
Welcome back to the community.
Are you losing connection on the 4G Hub and have to reboot to get connected again?
Do you have any other EE mobile devices that loose signal at the same time?
Thanks 🙂
jockwav1
Yes that`s what i am saying i have to reboot it on a daily basis.
I don,t have any more EE devices.
Leanne_T
Thanks @jockwav1
As this is happening daily, I would suggest getting in touch with our tech guides who can run troubleshooting to see why this may be happening and let you know what is needed to stop the device loosing connection.
jockwav1
Okay how do i get in touch with them,thanks.
Leanne_T
No problem @jockwav1
Contact details can be found on the Technical Support get in touch page.
Hope this helps 🙂
jockwav1
Thank you
jockwav1
I am getting nowhere with this,just going round in circles.
Leanne_T
Hi @jockwav1
If you select option 2 when you call  and then the option for technical support. Once a guide is available they will be able to help 🙂
jockwav1
Well did as you advised but they were really no help,after giving him permission to enter smarthub it is now even worse disconnecting all the more,so left worse off now.
