Smart Router / PS5 - NAT Type 1
Minty_Cymru
Hi all
Is it possible to get a NAT type 1 for a PS5 through a Smart Router?
I've
  • Assigned a static IP for the PS5
  • Forwarded ports 1935 & 3478 to 3480 (internal & external, TCP/UDP)
  • Also tried placing PS5 in the DMZ
None of the above works, the PS5 still reports a NAT Type 2.
14 REPLIES 14
Sorry Christopher I have EE 5G and like you I had NAT 2 and I was really happy......since a bit my NAT is 3 and there is nothing I can do about it...can you help me?
Should I change APN or what?
James_B
EE Community Manager
Hi @AndreaBu89,
Our Technical Support Team will be happy to take a look at this issue if you get in touch.
Whittaker_11
Im having the same issue did you ever resolve this
Hello FPS friend!
I achieved open nat type (nat1) by using a secondary gaming router plugged in via Lan to the EE router and putting the gaming router in the dmZ.
I used the gsming router open nat type function in game mode to automatically port forward to the correct port and it worked.
Every so often I would have to put the gaming router back in the dmz as it would sometimes replace it with another device.
I also had to asign a static ip to the ps5 and the gaming router to make it work.
By doing this, my graphics were improved, my lag was reduced, and it was a massively noticeable difference when in multiplayer games.
I have just upgraded my ee router to the smart hub plus and my usual way of getting open nat type isn't working. I'm yet to figure this out but hopefully I'll have time this weekend to find a solution.
@Kotchgunna1 : What was the EE router you had before with which you successfully did all this?
