Smart Router / PS5 - NAT Type 1
Minty_Cymru
Hi all
Is it possible to get a NAT type 1 for a PS5 through a Smart Router?
I've
  • Assigned a static IP for the PS5
  • Forwarded ports 1935 & 3478 to 3480 (internal & external, TCP/UDP)
  • Also tried placing PS5 in the DMZ
None of the above works, the PS5 still reports a NAT Type 2.
14 REPLIES 14
Christopher_G
Hi @Minty_Cymru
Welcome to the community.
Could you explain a bit about why you're looking to do that? Do you have a problem?
Minty_Cymru
Of course
When playing FPS shooter games, ping is king. In a 'shoot off' scenario I often find myself at a disadvantage due to a little latency. It's a battle I've been fighting for years 😂
My ping is quite good (15ms) although still going through a moderate nat (NAT Type 2) which means there is still some room for improvement.
I want to trial it in open nat (type 1) to see if it improves the performance.
Is it even possible to achieve a NAT Type 1 on this router? both of what I've done so far (port forward and DMZ) should give me a NAT type 1.
Christopher_G
OK thanks, @Minty_Cymru
Mine is defaulted to 'NAT Type 2' as well, and I'm a beast on Warzone. 😉
The only unofficial remedies that I can see from searching online is port forwarding, which you've said you already tried, as well as other things. I haven't read anything to say that changing the NAT type will improve your ping. It seems to be more for match-making and voice chat.
@XRaySpeX - Do you have any thoughts on this?
Don't understand consoles' NAT Types nor where they dream them up from. Routers don't have NAT Types.
Minty_Cymru
It's looking like this is in the 'no' category then 😂
I ain't no beast in any game (which is why I'm trying to improve my chances....)
I gave up on CoD when I switched from PS4 to PS5. I'm into BF2042 now, and have always played HC which means fastest gun wins.
Christopher_G
I may have been exaggerating, @Minty_Cymru
I've never played Battlefield before. I watched a couple of online streams when the last game came out. It looks a lot of fun. 🙂
Ian06
Hmmm yes NAT types is a strange way to describe this, but apparently that's what MS XBOX and Sony PS do.
What they are really talking about is how the router (or firewall) handles unsolicited incoming connection requests... in gamming, this is for starting up conversations or allowing people to join multiplayer games.
The game apps need to incoming connection requests to be forwarded to the PS or XBOX etc. so the external player can join.
Putting the games console in a DMZ or port forwarding to the console ought to solve the issue,  I guess to do this the games console needs to have a static IP - Dependant on the router used and it's capabilities.
pip11
Scholarly Contributor
There are 3 types of connection offered by Openreach to ISP's
1, Speed , which may not be stable.
2, Speed and stability, which balances the two.
3, Stability, which may sacrifice speed to ensure stability.
Most ISP's choose option 2.
I know a few gamers were switched to option 1 by BT a few years ago by request,  but if this is still possible or if EE even do it I don't know.
Mustrum
@Minty_Cymru  there are lots of good pages on the internet explaining NAT types, and the best you will get via any Router is type 2.
This article in PureVPN.com is one of the better ones I have seen.
Changing port types suggested by @pip11  won't make a difference to your NAT type, but
may reduce ping times slightly.
https://www.purevpn.com/blog/nat-types/
Putting your device in the DMZ and having a static IP would only be needed if you wanted to access your device from elsewhere on the internet, but leaves it very open to attack. Even if EE provided static IP's there are better ways to do things these days.
