Smart Hub Pro and IPV6
Iansuart
I have a 1G service FTTP with the smart hub pro and generally it is working.
looking through all the settings I have an issue on IPv6. The hub status is enabled but the IPv6 network status is disabled
I cannot find a method of enabling it and the guide I spoke to said it was done in the router hub manager. I can’t find any method of enabling it. I  have looked through the community and cannot find an answer,
Should this be enabled and if so how do I do it?
ian
13 REPLIES 13
That’s great. Thanks everyone for your help
ian
On that Advanced > IPv6 > Status page if you click the Config tab does ULA > Enabled say YES?
Yes it does
You should all be OK, IPv6-wise.
