Cannot receive calls to my landline, although I can dial out
Bunnyrat
I cannot receive incoming calls to my landline, although I can make outgoing calls, but only to other landline numbers NOT any mobile numbers. Calls can only be done from the phone plugged into the EE smart hub plus.  If I try the phone plugged directly into the phone socket it is DEAD.  When we try to call a mobile number, it appears to connect as the timer starts, but there is NO ringing tone and no connection.  Incoming calls to the landline receive an unobtainable tone.
Bunnyrat
It seems to be sorted now.
17 REPLIES 17
Bunnyrat
Yes I can call out, but only to landline numbers from the phone connected to our new smart hub plus router,. However, we cannot call any mobile numbers, it appears from the handset that the call has connected as the timer starts, but the is no ringing connection .  The second phone that is plugged directly into the phone socket is dead.
When trying to dial into my landline number you get an unobtainable tone
Bunnyrat
Daniel-S
Former EE Employee
Hi @Bunnyrat,
You may have had a fault that luckily corrected itself.
Hopefully it'll work as it's supposed to now but come back to us if it ever comes back.
Thank you
Daniel-S
We have exactly the same issue since we swapped form BT to EE and changes our router!
Any help most welcome,
many thanks
We have the same issue bit it hasn't sorted itself, all help most welcome
We have had the same issue for a month now, and neither BT nor EE have had any success trying to resolve it. We are beyond frustrated - have you had any luck getting it resolved? (We can make calls, but cannot receive any).
jonpearce
We had Full Fibre installed 2 days ago. Our landline phone can only dial out but anyone calling in gets an unobtainable tone. EE sent a new hub but that's worse! Just get a message with no dial tone and still no incoming calls. Put the original hub back so at least we can make calls. Doesn't solve the problem though. Not impressed with EE.
@jonpearce : Specify which hubs involved.
