Smart Hub Pro - How to change DNS settings?
goral
I am setting up Smart Hub Plus and want to change the DNS server to 1.1.1.1 but I don't know how, I can't find the option to change it anywhere.
Goole returns that the change is done this way:
Home > Advanced > My Network > IPv4 Config & switch DNS Servers Auto to OFF
But with me there is no such option in My Network.
Any help?
51 REPLIES 51
@Denzel99 No problem already had the wrath of the sky mods a few times, power hungry wanna be lot, just don't care myself.👍
HelpfulGherkin
Is this resolved now? I’ve found this option and managed to set my primary and secondary DNS to cloudflair
Denzel99
As far as I can tell, none of the latest ISP supplied routers can change DNS.
Call me paranoid, but a little thing called the Investigatory Powers Act perhaps?  Probably the easiest way of tracking what sites you’ve visited.
What hub do you have? As far as I know, it's possible with the Smart Hub Plus but not the Smart Hub Pro yet.
That’s right, I have the Plus. Not the Pro
ko5tas
Funny, when you search for DNS it actually returns a relevant result to change DNS:
which redirects to the advanced IPv4 config, which is empty.
Seems like the functionality is there but it's simply disabled...
@EE you can do better... please
@ko5tas : No, not the functionality; only the search subjects which are probably the same as for the SH+ where this does work.
Ewan15
Expert Contributor
Expert Contributor
@ko5tas I think EE want the GUI to be the same across their latest routers. So the placeholder is there on the Smart Hub Pro. Hopefully with the next firmware update, it will catch up with the Plus feature wise. 🤔
Kieran6670
Had a software update on my hub and smart wifi device yesterday as I had to repair the smart wifi to the hub and since then the option for changing DNS finally seems to have appeared.
@Kieran6670 Good going for EE slow but sure!
