Smart Hub Pro - How to change DNS settings?
goral
I am setting up Smart Hub Plus and want to change the DNS server to 1.1.1.1 but I don't know how, I can't find the option to change it anywhere.
Goole returns that the change is done this way:
Home > Advanced > My Network > IPv4 Config & switch DNS Servers Auto to OFF
But with me there is no such option in My Network.
Any help?
51 REPLIES 51
Ewan15
Expert Contributor
Expert Contributor
@Kieran6670 When you use the new DNS option you end up with three DNS entries on your device.
The first two are what you have set and the third is the hub gateway
I’m still using the BT home hub 2 but there is no update available. Will call in the local EE store and ask for the EE hub. Thanks for the update.
@Eddiemander Are you currently having a DNS issue with the old BT Smarthub2 you are using!
Eddiemander
Many thanks for the reply, yes there is still  no way the change the DNS settings.
@Eddiemander There never was so never will more than likely with a BT Smarthub2.
Thanks buddy, into EE tomorrow morning for me.
@Eddiemander What are you trying to do, EE will just give you the BT equivalent and that will not have DNS also!
GamerGee
I've recently just had the latest smart hub forced upon me because of the digital telephone upgrade. To say I am not happy is a bit of an understatement. I use a raspberrypi which hosts PiVPN (which is working) but also PiHole which acts as my DHCP and recursive DNS server. Unfortunately, I cannot make use of the DNS at the moment because I cannot set the DNS server to what I want it to be. Even though I could set it in the TCP/IP stack, this is not ideal.
This is a really poor decision from EE/BT and as a result I will now be investing in a third party router to setup my home wifi how I want it and the smart hub will literally just become the equivalent of a DSL modem.
If any bigwigs at EE read this (probably not), stop taking functionality away from your customers!
I don't understand the problem, could you elaborate?
You configure Pihole to use an upstream DNS server, and this configuration is entirely independent to your router. What DNS resolver are you using as upstream in Pihole? Why can't you 'set' it?
The ability to configure the hub to use custom DNS servers is present in the latest firmware. If you have only just installed your hub then it may take a day or two for it to be upgraded. However, the custom DNS function on the EE hubs relies on DHCP i.e. the hub issues the custom DNS server to connecting devices as part of the DHCP lease. If you are using the Pihole for DHCP then I assume you have DHCP disabled in the hub (bad if not), so the feature being available to you isn't going to make a jot of difference anyway.
Source: I use Pihole for DHCP/DNS and it works perfectly fine with EE hubs.
Richardn1748
Simple answer you can't like many options/settings within these routers your are completely locked out. The dns is locked out for 1 simple purpose and thats so they can watch trace and gather all of your data and sell it. I strongly suggest you go to every single device you have connected to it and manually change the dns to cloudflare to stop them seeing every website you visit and stealing your data then think seriously about drop kicking the hub out the window and go buy yourself a real router. The other reason many of the settings are locked out is because of all the people out there who mess around in the settings when they haven't got a clue what there doing and mess up the connection leading to service calls to fix what they've messed up unfortunately the rest of us that do know have to suffer only way out is to buy a real router that dont have a nanny and a thief built into it my friend sorry.
