Smart Hub 7 Pro - No FW Updates!
mikefairgrieve
Anybody else still sitting at  r3.8.24-R-1531355-PROD-1 from last year? Seen all the updated firmwares getting applied (although some a bit iffy) , just curious if anybody else is still waiting?
10 REPLIES 10
Ewan15
Expert Contributor
Expert Contributor
@mikefairgrieve My firmware has not yet updated from r3.8.26-R-1595999-PROD-1
Maestro
Maestro
@mikefairgrieve @Ewan15 There is a new Pro version out, still waiting on @James_B having the feedback if problematic or stability issue, update may have been pulled currently so you are both aware..... currently as below and posted elsewhere with few problems on the post's.
FW: r3.8.24-R-1531355-PROD-1 and the gui is at App version 3.1.3. 17/09/2025 Now https://
FW: r3.8.25-R-1595997-PROD-1 and the gui is at App version ?.?.?. 23/12/2025
FW: r3.8.26-R-1595999-PROD-1 and the gui is at App Version is 3.1.3.19 24/12/2025
FW: r4.28.1-R-1882725-PROD-1 and the gui is at App Version is 3.14.5 31/05/2026 Stability Problem
Profile closed
Not applicable
It's quite bad that these hubs aren't getting updated regularly. There have been a bunch of vulnerabilities in older versions of OpenWrt that these are based on.
Tempted to buy a Flint 2 and install native OpenWRT on it.
@Profile closed Go for it buy your own and setup the best way and the best operating system that it will support.
widdowsonben
Skilled Contributor
Skilled Contributor
I appear to be on r3.8.26-R-1595999-PROD-1 with my 7pro
EE / BTTV user since BT Vision - EE FTTC (Smart Hub 7 Pro), EE TV (Apple TV).
Starlink for a backup.
@widdowsonben Looking likely that is were you will be staying then currently.
widdowsonben
Skilled Contributor
Skilled Contributor
Yeh. Not sure what advantage the newer FW brings other than security? It’s a bit overkill here anyway as I’m stuck on a fttc line.
@widdowsonben An FTTC line with a 7 Pro Hub, so you must have an old VDSL modem in front of your Pro connection?
See from your earlier post's waiting on OR getting there act together for a FTTP connection, good news in my case anyway FTTP works well, now been on EE to Sky to Vodafone and no issues Fibre wise with any connection that way.
widdowsonben
Skilled Contributor
Skilled Contributor
Yeh it sits behind an Openreach modem. No chance of Fttp here for the meantime so stuck with this setup.
