11-01-2026 10:45 AM
Hi All,
Another Issue with the Hub 7 Plus, probably on others too.
When i create a Port forwarding rule, it always comes up with an error and doesn't save or eventually when it does save, it has created duplicate rules. Try to remove one and it removes both, aaarrrgghh! These EE hub are very frustrating.
I hope someone who can help sees this and my other post, to help fix these issues.
20-03-2026 12:05 PM
Looks like my image was blocked
Firmware Version is r3.35.24-R-1648110-PROD-84001
I had exactly same problem as you months ago until i got the above firmware update
Yes both my ports show open, my reverse proxy wouldn't work,otherwise
20-03-2026 12:11 PM
Above is my firmware, I had same issue as you until it updated to this version
20-03-2026 12:18 PM
Hi, looking different to mine. I only unplugged my router last week, swapping back to Hub 2. Looks like they have done another update, as this is mine.
20-03-2026 12:21 PM
i am on r3.35.24-R-1648110-PROD-84001
i had exactly the same issue as you until my hub got the above firmware
20-03-2026 12:26 PM
Then you need to get it updated. Mine updated months ago
That's almost certainly your problem
20-03-2026 12:29 PM - edited 20-03-2026 12:36 PM
@Pecbeck Seen your message so you are not blocked, and correct about the FW version.
@SamyM As from your posting earlier you have had multiple EE Hubs sent to you, and you are reporting yes you had an update, now your screen capture is showing one version back, leave the hub on at let it do a FW update to the latest, once done power it off for 5 minutes and restart again.
20-03-2026 01:22 PM
I recall I may have had to perform factory reset after my update, but it was a while back so @SamyM I would probably do a factory reset once you confirm hub has updated to the latest as mentioned above
20-03-2026 02:22 PM
Hi, My router seems to have updated to r3.35.23-R-1648107-PROD-84001 but it seems to need to do another update to get to r3.35.24-R-1648110-PROD-84001 from previous communications. I will leave it overnight and see what happens.
Samy
22-03-2026 06:46 PM
Hi, My EE Hub 7 Plus has now updated to App version:3.11.3, Firmware version: r3.35.24-R-1648110-PROD-84001. Still cannot get port forwarding to work. Anybody had any success port forwarding on the EE Hub 7 Plus? I have done a factory reset and reconfigured port 21. No success. There is issues with EE Hub 7 Plus. what do others think? Got lots of issues trying to update the rules. I attach some screen shots
Samy
