26-01-2023 09:50 PM
Hi folks
Completely new to this forum, but hoping someone might be able to assist and I can't find a 'contact us' facility to ask the company.
I have broadband, the wifi from which is, although not quite as promised, absolutely fine for my needs on laptops and phones, pretty well anywhere in the house. However, my smart tv is appallingly poor, with constant buffering on all stations, Netflix, etc. I assume that the same wifi should be the same for both, so why is my tv not performing in a similar way, please?
Any help would be hugely appreciated.
26-01-2023 11:53 PM
@S2y : Last rime you were here you were talking about fixed landline Home BB. Are you now asking about mobile BB with a mobile router with a SIM (which this thread is)?
27-01-2023
03:57 PM
- last edited on
27-01-2023
05:01 PM
DanielPA
Hi
This is the same issue, really. The internet broadband to laptops and
phones is pretty good. Across the room, a mere 2m away, the TV is now so
bad that I've had to link it by ethernet cable to the router to be able to
watch anything. Without the cable, we would watch nothing at all. That
said, the cable itself is a health and safety trip hazard, trailing as it
does through two rooms and a hallway, a distance of about sixteen metres.
Is my router in the wrong place?
Kind regards & richest blessings
*xxxxxxx*
xxxxxxx xxxxxxxx
'xxxxxxxxx'
xxx xxxxx
xxxxxx xxxxxxx
xxx xxx
[email protected]
xxxxx xxxxxx
xxxxx xxxxxx
[Mod edit: Please do not post personal information on the public board. Thanks!]
27-01-2023 04:05 PM
OK, don't tell me whether it's fixed or mobile BB & its router. So can't help you!
27-01-2023
04:43 PM
- last edited on
27-01-2023
05:12 PM
DanielPA
Apologies; when I said it was the same problem as before, I thought this
implied that it was a fixed router. I am not at all technically minded,
and wouldn't know the difference anyway. You will have gathered, though,
that the TV is about sixteen metres from the router.
*xxxxxxx*
xxxxxxx xxxxxxxx
'xxxxxxxxx'
xxx xxxxx
xxxxxx xxxxxxx
xxx xxx
[email protected]
xxxxx xxxxxx
xxxxx xxxxxx
27-01-2023 04:57 PM
@S2y : Which BB router is it?
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
27-01-2023 05:06 PM
You've also posted your phone numbers & email address on a public internet forum, presumably because you're using the email interface to respond to these posts.
Unless you want to start attracting spammers, I'd strongly recommend you remove those from the forum.
27-01-2023 05:41 PM
Did I say I wasn't in the slightest technically minded? 😂
27-01-2023 06:05 PM
Now take a look at the questions that @XRaySpeX has posed above - responding to those will enable further assistance.
27-01-2023 06:18 PM
Well, that was a challenge for a clueless person. I don't know if I've managed to do as you asked, but it is my best shot. I can also confirm that I don't understand a word of either document. Cheers - and thanks.
