New router wont connect to printer WiFi
Stainless
New EE router installed replacing BT smart Hub 2 . Cannot connect wirelessly to printer Epson Stylus OFFICE BX630 FW.Tried entering SSID , Passwords from router etc  nothing
That's a decade old printer. Try setting up Compatible WiFi on the router under Advanced > Wireless Settings > Config > Compatible WiFi (it defaults to 2.4 GHz & WPA2) & connect your problematic 2.4 GHz devices to that.
Maestro
Maestro
@Stainless You may just have to set up the compatible mode on your new hub, or disable the 5Ghz temporary to see if it can connect, more than likely does not like the WPA3-T as it connected on your old BT Smarthub2... You can keep and continue to use the BT hub, it works fine on a EE service.
Connect your devices using Compatible WiFi | Broadband Help | EE
Epson Stylus Office BX630FW Support | Epson United Kingdom
Northerner
Hi @Stainless
Tried these suggestions:
https://www.epson.co.uk/en_GB/support/sc/epson-stylus-office-bx630fw/s/s1065?srsltid=AfmBOooZmTVzVxK...
Stainless
All working now after setting up Compatible WiFi
