on 20-05-2026 08:55 PM
So I have been on the full fibre 1.6Gbps service for a couple years.
i recently noticed that i was paying more than I should be so I voted to re-up my broadband at £71.99 from £75.99 and that includes new WiFi 7 hardware in place of the old WiFi 6 hardware. However I don’t need the new hardware because I currently have an ASUS BE-98 Wifi7 router and have my hardware set up how I like it including a NAS and custom setting for all my WiFi channels.
the question I have is can I continue to use my own hardware?
on 20-05-2026 08:59 PM
Yes, as long as you don't have DV but you may have to put your EE supplied router back in if you ever have to seek support.
on 20-05-2026 09:07 PM
I presume the config for enabling the connection won’t change I.e username will remain as [email protected] etc…
on 20-05-2026 10:36 PM
Yes, In Using & Configuring a Third Party Router you'll find everything you need to set up your router incl. the BB PPPoE creds. which are now the same as BT's. I thought you had already set it up & so didn't need this.
on 20-05-2026 10:45 PM
I don’t, in my reply I was questioning whether there was any change in the configuration, perhaps required to emulate the Wifi7 EE Hardware. So based on what you have said I won’t have to change a thing which is exactly what I was hoping to be the case
