Delayed installation, Help needed
JayG33
Hi mods.
My new fibre installation is delayed and it's affecting my work. Can an escalation manager please look into my order details to see if an appointment pull forward is possible? Thank you.
JAMES
Northerner
Hi @JayG33
You'll need to speak to EE CS on 150 directly.
https://ee.co.uk/help/contact-ee
Northerner
Hi @JayG33
I have tried that and been told that's an Openreach issue. I can't get them to speak to me as an end user so was hoping EE would ask them to expedite my request.
JAMES
@JayG33 Past experience nothing get's pulled forward on an install, it only every get's delayed further in time. What is it that you are having done ie existing system upgrading to a new FF connection, or nothing at present waiting on an install to happen?
Thanks for the reply. I am upgrading an old copper connection to brand new Full Fibre, so I am waiting for the full physical install. Hopefully an official EE moderator can drop by this thread soon to look at my options!
JAMES
Your only option is to keep on at CS for them to set an installation date. It can't be escalated from this user discussion forum.
