08-01-2023 12:10 PM
I switched to EE fibre broadband but the speed has been terribly slow lately and keeps getting disconnected. Started off nicely but got worse and worse and it is almost unusable lately. What’s going on?
08-01-2023 12:13 PM
@Fengli : Welcome to EE's Home Broadband Forum.
