26-12-2022 01:00 PM
Reported regular dropouts twice now. We had a BT engineer out a few weeks ago to 'repair' our loss of landline and internet, but since then it has dropped out intermittently for a few minutes at a time. The fact it's intermittent means that it comes back on when I'm the middle of reporting it!
We're only getting about 1.2 Mbps at the best of times. It was pretty reliable up to the time of repair, but now ithe dropouts are getting REALLY ANNOYING.
Hopefully a support advisor will read this and look into it.
Merry Christmas....
26-12-2022 01:10 PM
@Dennis66 there is no one on here who has account access. You will need to contact the Broadband Care Team to get someone to look at your fault.
26-12-2022 01:13 PM
26-12-2022 01:57 PM
Thank for responding on Boxing Day!
I'm using a TP-Link Archer VR400 router and can only find this:
Upstream Downstream
| Current Rate(kbps) | 673 | 1415 |
| Max Rate(kbps) | 707 | 2036 |
| SNR Margin(dB) | 6.8 | 9.7 |
| Line Attenuation(dB) | 43.7 | 67 |
| Errors(pkts) | 407017 | 872864 |
Speedtest link:
https://www.thinkbroadband.com/speedtest/1672062418165156755
| 330 | 50 | -- | Available | -- |
| Up to 1 | -- | 1 to 3 | Available | -- |
| Up to 0.75 | -- | 0.75 to 2.5 | Available | -- |
| 0.5 | -- | -- | Available | -- |
| Up to 1 | -- | 1 to 3 | -- | -- |
| Up to 0.75 | -- | -- | -- | |
| Up to 0.5 | -- | 0.75 to 2.5 | -- | -- |
| 1.62 |
| 0.75 |
| 2022-12-09 |
| Available |
| U |
| N |
| N |
| Y |
FTTP is not available.
The exchange is not in a current fibre priority programme
WLR is currently available at the exchange
SOADSL is restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
26-12-2022 02:00 PM
I know, but like I said, the dropouts are so temporary that by the time I get through on the phone the connection is back up and they cannot see the fault. I think they can see the line history and problems, but last time I was advised to just keep an eye on the connection.
I will call them again once the holidays (and strikes) are over.
26-12-2022 02:34 PM
It looks like you are quite a long way from the exchange but your speeds are within the expected range.
Do you notice any noise on the line, especially when you get the drop outs?
Or is it worse when it is windy or raining?
Is the line quiet, dial 17070 option 2, preferably using a corded phone.
26-12-2022 03:24 PM
Yes, but we were getting slightly higher speeds before the repair (around 1.7 Mbps). And it's not so much the drop in speed as the unreliability of connection.
Can't say I've noticed undue noise, but there is a crackling on the line.
Haven't tried the noise test with bad weather, but it will be something to try next.
Yes. there is some slight crackilng on the line with the corded phone.
26-12-2022 03:33 PM
Your speeds will have reduced due the noise on the line.
I would report a noisy line phone fault, once that is sorted your speeds should increase again.
26-12-2022 05:55 PM
You can only get the ADSL that you are on there & have an awfully long line. You are probably getting as fast as you can get.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
27-12-2022 06:45 AM - edited 27-12-2022 06:45 AM
Thanks. I'm already using the test socket, but I will check for line noise next time the connection drops out. I didn't know about the 17070 option so thats something new I've learned.
I'll report the line noise back to EE once the holidays are over.
Thanks again guys, have a good New Year.
