Broadband dropouts
Dennis66
Reported regular dropouts twice now. We had a BT engineer out a few weeks ago to 'repair' our loss of landline and internet, but since then it has dropped out intermittently for a few minutes at a time. The fact it's intermittent means that it comes back on when I'm the middle of reporting it!
We're only getting about 1.2 Mbps at the best of times. It was pretty reliable up to the time of repair, but now ithe dropouts are getting REALLY ANNOYING.
Hopefully a support advisor will read this and look into it.
Merry Christmas....
26 REPLIES 26
Dennis66
This is using G.DMT and the test socket...
DSL Status
This page shows information about your DSL connection. If you are using Fibre/Ethernet Broadband then this page is not applicable.
Status
  Configured CurrentLine StatusLink TypeOperation Mode
--UP
--Interleaved Path
AutomaticG.992.1 (G.DMT)
Data Rate Information
UpstreamDownstream
544 (Kbps)
1120 (Kbps)
Defect/Failure Indication
Operation Data Upstream DownstreamNoise MarginLine Attenuation
9.0 (dB)10.4 (dB)
31.5 (dB)63.5 (dB)
Indicator Name Near End Indicator Far End IndicatorOutput PowerFast Path FEC CorrectionInterleaved Path FEC CorrectionFast Path CRC ErrorInterleaved Path CRC ErrorLoss of Signal DefectFast Path HEC Error STRInterleaved Path HEC ErrorError Seconds
12.3 (dBm)16.6 (dBm)
5273
0102
00
0310
562312
Statistics
Received DataTransmitted Data
10 (Kbits)
6 (Kbits)
Umm! It's not going in the direction I would have expected.
All this chopping & changing & the resultant resyncs could be causing the DLM to be damping your line. I would advise you run on ADSL2 only from the test socket for a few days & then post router stats.
I'm a bit suspicious that in both stats the Status / Configured / Operation Mode says "Auto". It should be the ADSL Mode you choose.
Dennis66
Should I mention this to the BT engineer when he comes out tomorrow, or chenge it back to ADSL2+ ?
If it were me I'd never run on ADSL2+ on your long line.
Dennis66
Okay. I'll say that on EE advice i've changed the mode to ADSL2.
I'm not EE! I'm just a user like you. I do not represent EE in any way.
Dennis66
Okay, then I'll say it's been recommended that I change from ADSL2+ to ADSL2.
Thanks for the help and advice.
