on 02-11-2024 03:01 PM
Just switched from sky Wi-Fi to EE, the general speeds are much better and averaging around 200-400 mbps download speed however about every 10,15,20 seconds ill get really bad spikes in ping for a few seconds.
does anyone know how to fix this please?(cant use ethernet)
on 03-11-2024 12:07 PM
@JimM11 : Yes, Wireless.
on 03-11-2024 12:19 PM
@XRaySpeX confused, are you saying on wireless that you would expect a lower ping?
on 03-11-2024 07:19 PM
on 03-11-2024 07:48 PM
@chillies What is the single wireless device that you are using, can you also http://192.168.1.254 status on the router, capture screen and post the picture up.
on 03-11-2024 08:36 PM
im on my computer
on 03-11-2024 08:39 PM
@chillies When the pictures is cleared will have a look.
on 03-11-2024 08:44 PM
@JimM11 just done that.
03-11-2024 08:58 PM - edited 03-11-2024 09:06 PM
@chillies Your status looks good, up day's connected to a high speed ONT at full wan speed, Next screen is the overall first screen, you will have to hide your SSID so erase or overfill, pic's just take a little time for clearance. It can take only one device on wireless, to interrupt and cause chaos on wireless, cannot confirm if it's a router/fttp until wed when i get installed, but 8 months on fttc, no wireless issues what so ever. Will again watch for pic.
How difficult for you to get Ethernet connected to the router?
If you could also let me know if you also have any extenders, using wifi enhancer software addon, and take it you may be gamming on your PC?
on 03-11-2024 09:01 PM
I don't think I would be able to connect by ethernet unless I were to drill holes in walls and run the ethernet cable up walls and through ceilings but thanks. Do you think I should get an engineer to have a look?
03-11-2024 09:14 PM - edited 03-11-2024 09:20 PM
@chillies No regarding the Ethernet, don't worry about that was just asking, trying to get a feeling for the system, will go back re-read your input from the start of the post.
Not much info, switch from sky to ee, was it fttp to fttp also so just straight router switch over, with sky where you on sky max with the latest white sky router, AND you do not have any of the sky boosters if you had still connected.
