How do l switch from 5g to 2.4g on my smart hub SH35A
MALLAW
how do you make my smart hub 5g and 2.4g ready
12 REPLIES 12
Maestro
Maestro
@MALLAW It's already 2.4Ghz/5Ghz ready as a single ssid dual band wifi 7 hub. See the link below about it all.
EE Smart Hub 7 Device Guide | Broadband Help
I am unable to connect important services require 2.4g
Please assist with simple instructions on how to fix
Kind Regards
Sent from the all-new AOL app for iOS
@MALLAW Here is the link that may help you. The Forum is NOT EE CS.
Set up and use Compatible WiFi | Broadband Help | EE
MALLAW
Hi
how do l get assess to 2.4 and 5 g on my smart hub SH35A
i have important equipment that needs to be connected to 2.4 and is preventing it from working please advise urgently
@MALLAW You can either use the app to access the EE Hub or do the web manager interface on http://192.168.1.254 as per the link also above earlier in the posting.
Your devices select what connection to take, and you cannot split the bands to have individual frequency selection. Main/Compatible will give you an extra choice.
I need to connect to 2.4ghz for specific software.
Please advise how to overcome this issue
Kind regards
M Law
@MALLAW Did you have a working system before, and if so were you using a BT or EE hub?
My solar system was fully functional with no connection issues.
It the system is 2.4 & 5ghz what is preventing connection.
Please advise
M Law
@MALLAW Then you may have to setup the 2.4Ghz compatible network and be sure it's on WPA2-Personal mode, after that the signal has to reach either the hub or the smart wireless extender if you are using any. If you have an previous working EE/BT Hub, just put it back on the connection.
