14-09-2023 05:52 PM
Hi I need it PPOE Username and password I can't find them anywhere and I can't find an email to contact customer services
14-09-2023 06:01 PM
Are you not using an EE router? Normally they will be auto populated into it the 1st time you connect..
Besides that EE BB Username & Pwd, which you should have been given by email, you may use instead BT's creds of [email protected] / BT.
In Using and configuring a third party router you'll find everything you need to set up your own router.
EE maintain no email contact.
14-09-2023 10:54 PM
14-09-2023 11:35 PM
Yes, I just gave them to you.
15-09-2023
12:16 AM
- last edited on
15-09-2023
07:20 AM
DanielPA
Oh sorry thanks I did not understand, tomorrow I try
