16-10-2023 07:36 PM
Greetings,
I bought the EE 4G mobile wifi a while ago, and am trying to top it up for the first time. I still have the Top-up and Keep me card, but want to top it up online. I remember there was a website which I could log into to check the data, but can't find it. On the back of the device, if I log onto the listed http:// site, it asks for a username and password, but only the password is listed on the device. Any idea the username, or how I can find the site with the data info?
I don't even remember how much I'm supposed to top up with if I take the card to the shop, which is why I'd prefer to do it online.
Many thanks in advance!
16-10-2023 08:00 PM
Yes, it looks like your PAYG SIM has been lost after such long time of non-use.
EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack or add-on.
16-10-2023 07:41 PM
Quick update, the site popped up when I logged onto the network, but it says "invalid SIM." Is this because it has no credit?
16-10-2023 07:47 PM
16-10-2023 07:50 PM
How's long is "a while ago"? When did you last use that SIM to make a chargeable action?
16-10-2023 07:53 PM
Thanks, one problem though is that I don't know the number to top up with. The SIM itself has a number which would be too long. The top up card also has a number more than what a mobile number would be.
16-10-2023 07:54 PM
My point 2. will tell you.
16-10-2023 07:56 PM
Sorry just seeing that. It was definitely well over a year at least. Has it probably been cut off by now?
16-10-2023 08:00 PM
16-10-2023 08:54 PM
I see, guess I'll pick up a new one then, and that should sort everything. Many thanks Grand Master!
16-10-2023 08:58 PM
Yes, that should fix it.
