30-07-2025 11:52 PM
I upgraded to Fibre a while back and i'm only getting about 20-30 mb/s so i'm not sure if its just slow here but i don't know if anyone upgraded the cables i think im still running off the old phone lines i'm not really sure what going on just trying to cover my bases
30-07-2025 11:59 PM - edited 31-07-2025 12:03 AM
@vile_breath if you have not updated the lines to you property then it is likley that your fibre is only to the cabinet - green box or FTTC. Your speeds will depend on the condition of your line and the distance to the cabinet, sounds like it is a long way away.
If you were able to get full fibre, FTTP, then you could get much faster speeds and the distance to the exchange would be irrelevant.
As a starter for 10, enter your post code in the Openreach checker then pick your address from the drop down to see the max speeds you could get. https://www.openreach.com/
31-07-2025 05:49 AM
i have just checked on the open reach checker and it says up to 1600mps and in the other box it says up to 115mps i am on the Fibre Plus Broadband without landline plan
31-07-2025 06:35 AM - edited 31-07-2025 06:37 AM
Fibre Plus BB won't get you the speeds you see the OR Checker offers but only up to 80 Meg.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
01-08-2025 12:10 AM
Don't worry i got it sorted now😀
01-08-2025 09:26 AM
@vile_breath are you not going to share what fixed it?
01-08-2025 11:37 PM
engineer coming out
02-08-2025 12:28 AM
So not fixed yet!
