EE wifi hotspot
nobuoittetsu
i'm using ee hotspot wifi on a macbook running OS14.4.1.
wifi often gets a exclamtion mark and disconnected.
I then need to turn off and on wifi and log onto ee wifi again.
it happens 10 times a day. this is very annoying because every time  I need to manually put the username and the password in order to log onto ee wifi hotspot.
I tried forgetting network but didn't work. This happens when I'm not using VPN.
what is the solution?
6 REPLIES 6
@nobuoittetsu are you using an EE wifi hotspot (public WiFi connection). or your own WiFi connection from your own router within your home or work place ?
Which router do you have?
nobuoittetsu
I'm using EE wifi hotspot (public WiFi connection).
Not my own Wifi connection. So I don't have a router.
@nobuoittetsu  Does it cut out when you’re using it or not using the MacBook
nobuoittetsu
Wifi cuts out while I'm using the macbook.
nobuoittetsu
Where is EE support team? Do they not help here?
