EE vs BT broadband which is better for gaming?
Suzi82
Hi
currently with BT broadband not sure whether to upgrade with BT or EE
which is best for gaming?
thanks.
They are the same!
@Suzi82  Anything that uses your current phone line is the same it’s just different prices/speeds depending on what you pay for.     The only company that doesn’t use the phone line is virgin media as they have their own lines, which I’m sure you might know are underground and not from a telephone post.
bobpullen
There are some paid for gaming-orientated features provided with EE and the Smart Hub Plus that are not provided with BT. See here for detail. EE also supply 1.6gbps Fibre if it interests you, whereas BT do not.
Full fibre isn't phone line they take the old copper down... fibre is fibre.. but vm is cable to fibre and it's showing its age.
Suzi82
I’m looking just for broadband as currently with BT no phone just broadband.
