EE smart hub flashing yellow for three hours now
jakobexmachina
Title. Call support office is closed and apparently there’s no reported problems in my area, but my internet went down three hours ago and the smart hub has been flashing yellow since. Taken every piece of advice I can, turned it on/off, nothing.
6 REPLIES 6
James_B
EE Community Manager
Hi @jakobexmachina,
Is your internet connection still down this morning?
came back early afternoon next day, and now it’s doing the same thing again (1am)
Leanne_T
Hi @jakobexmachina
Thanks for coming back to us.
Please give our Broadband Care team a call on 0800 079 8586 and they will help you with the Smart Hub.
Thanks 🙂
If you would like help with your BB speed or connection issues, please would you carry out the following steps when it is up, which will help us to diagnose the problem and advise you further. Do not restart your router to do these tests:
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
Claire261964
My WiFi is doing the same as yours, did you find a resolution?
@Claire261964   if you follow the steps in the post above from @XRaySpeX  and report the results we should be able to help you.
Otherwise follow the steps in the Help pages.
https://ee.co.uk/help/help-new/broadband-and-landline/home-broadband/how-can-i-fix-my-home-broadband...
